craig
1
theta-client is the official open source SDK from RICOH. It allows easy access to the WebAPI for the RICOH THETA camera line.
I’ve built the demo-ios sample Swift application and ran it on iOS 18, both a physical device as well as numerous simulators.
In Viewer360.swift, I made a small modification.
original with underscore
config.setValue(true, forKey: "_allowUniversalAccessFromFileURLs")
modification with no underscore
config.setValue(true, forKey: "allowUniversalAccessFromFileURLs")
all functionality works
- take picture
- list files
- live preview with no frame glitches
- view image after take picture
- view image from list files
environment
- Xcode 16.2
- MacOS 16.2
- iOS 18.0 on simulator
- iOS 18.1 on physical device
- RICOH THETA X with fw 2.63.0
viewer
list files
live preview and take picture
craig
2
Now with iOS 18.2 on Physical Device
image view works with no problems
Live Preview Works with No problems
Network configuration
Client Mode
In ThetaSdk.swfit
class Theta {
static let endPoint: String = "http://192.168.86.163"
var thetaRepository: ThetaRepository?
var lastInfo: ThetaInfo?
func reset() {
thetaRepository = nil
func initialize() async throws {
if thetaRepository != nil {
return
var config: ThetaRepository.Config?
// Client mode authentication settings
config = ThetaRepository.Config()
config?.clientMode = DigestAuth(username: "THETAYR14113409", password: "14113409")
I tested the following with client mode:
- live preview
- take picture
- list files - to get data
