Hi everyone !
For a photogrammetric project, I would like to take RAW pictures every 2 or 3 seconds while waking. I don’t have enough time to deep dive myself into programming, is there a plugin which exists for this ?
Thanks a lot !
Etienne
Hi everyone !
Thanks a lot !
Etienne
I don’t think the plug-in you want exists. However, maybe other people have ideas.
As far as I know, this plug-in will only take up to 9 shots.
I don’t think this plug-in can meet your requirements either
For interval shooting on the Z1 for DNG, I don’t think you’re going to get much lower than the 10 second interval available in the webAPI
I have not tried it, so maybe someone else has a solution.
Thanks a lot for your answer !
Unfortunately I know those plugins and they are not appropriate for my subject …
Do you need the DNG image? Or, can you use the JPEG image from the Z1?
Even if you use the CameraAPI from the plug-in, I don’t think the DNG image can be taken every 3 seconds. You may be able to take the JPG image in dual-fisheye.
I’ll try and find out the fastest observed time for the DNG image.
About 5 years ago, Ichi Hirota built a prototype of his dual-fisheye plugin. I think he built the original prototype in less than a day. The plug-in reduced the time between images on the THETA V to less than 1 second.
Hello !
It would be better to have the DNG image, but if I have the JPEG, it is fine too.
The only thing that I absolutely need is the dual fisheye image before stitching. Is there a way to get it with JPEG, so I can take pictures in less than 10 seconds ? The plugins I found give only the DNG dual fisheye images.
Best regards,
Etienne
Thank you for the information on your requirements. Once you have the dual-fisheye image, are you planning to stitch the images with your system? Or, are dual-fisheye images better for photogrammetry?
I’m first trying to figure out what is technically possible with the camera.
It may be possible to take a DNG image at intervals lower than 10 seconds. The JPG would likely be even lower than the DNG.
This plug-in was taking the JPG images from the V at 1 second intervals.
It’s possible that someone could modify it to work with the Z1 or use the main idea with the new plug-in SDK for the Z1.
My plan is to walk on Lausanne’s streets (in Switzerland) with the camera to take pictures while waking. Then, I won’t stich the images, I will split the dual fisheye image in 2 different images, to use it in a photogrammetry software.
Attached to this email, you will find the kind of photo I will use (I split automatically the dual fisheye image with a python algorithm, here it is JPEG to be able to send it to you).
Again, thanks a lot for your help !
If you use a dual-fisheye JPEG image you can take the image at around 4 sec intervals with the webapi. If you use DNG+JPG, it will be around 7 seconds.
I have not tried this with tasker, but you may be able to wait 4 seconds between shots without having to build a mobile app or plug-in.
Thanks a lot for your help !
