my ricoh theta v camera turns on normally, but when it goes to connect to the app, the red light appears, there is a beep and it turns off. The battery was at 100%.
Would anyone have a solution?
thanks
Have you upgraded the THETA V firmware? What firmware are you running?
You can use the desktop app and a USB cable.
yea
it has the latest firmware. battery always 100%. there are many reports of this problem and ricoh from America does not respond to customers.
Obter o Outlook para Android
Note that I don’t work for RICOH, so this is just one user to another.
My personal opinion of what I would try, one by one:
- make sure you are powering off the camera, by pressing the power button for 10 seconds
- delete all images and media from the camera (move it to your computer)
- uninstall all the plug-ins
- reset the settings with this plug-in by john parmalee Settings Reset | RICOH THETA Plug-in Store
OK! I appreciate your help. I saw reports similar to mine and I believe it must be the same firmware. but I will carry out the procedures. thanks
