Hi All,
I have a Theta V that was knocked down during filming and died on me.
Managed to get it to boot up after discovering a loose connector in it.
It can connect to my android phone and PC with no issue at all. However, when I try to connect it to the Theta app, it will have 5 beeps + flashing red light and disconnect itself. When I press the wifi button, it will repeat the same beeps n red light. Need to force shut down after that.
I have tried to reset it by using the plug-in but failed. Failed as in the camera simply shut off after the red light. It did not restart. The same problem still persist after I have boot it up.
As Theta V is a discontinued product, Ricoh refused to do any repair.
Anyone has any idea on what is wrong with it and any solution?
Any help is much appreciated.
Thank you
