Theta V stuck in boot loop
My Theta V refuses to boot. All it does is slowly blink blue on the power button and the indicator light above the shutter button. It does this for what seems like minutes before it stops, otherwise I have to hold power + wifi for a few seconds to make it stop.
The wifi and camera lights never turn on, the wifi never appears on my phone’s wifi scanner, and Windows doesn’t see it when connected to my PC via USB (I’ve tried multiple cables, too).
I’ve googled high and low for fixes to try. I’ve tried every combination of button holding for various lengths of time that people say will reset it, but to no avail.
I opened the camera and removed the battery and popped in another. No change.
I charged the original battery in an external charger. Didn’t help.
Is there anything else I can try?
I’m assuming you’re at wits end and are on verge of tossing it.
In you’re desperate and are just thinking of throwing it away, then in order of lowest risk to highest risk
  1. delete all media
  2. reset all settings using API if you can get to it (which it appears you can’t get to API)
  3. apply for plug-in partner program to get development mode access. then perform factory reset using Android (internal camera OS) settings. see article below
  4. reboot bootloader (must be in dev mode)
As the lens assembly is still intact, you can shop online for a working unit with cracked lenses and then preform the swap on the entire lens assembly. Alternately, you can try and sell it as a working lens assembly and body.
Hi Craig. Thanks for your reply.
I’ll try joining the partner program. I should note that when I run the Ricoh Theta Windows app and try to connect, it doesn’t detect the camera at all. This happens when I click Plug-In > Developer Mode… and when I click File > Firmware Update…
In the meantime, I definitely can’t access the camera via USB or Wifi to delete anything or reset it. Is there any combination of buttons I could press that would initiate a factory reset?
By the way, does the little recessed button on the bottom (near the 3.5mm jack) do anything? I tried pressing it but I don’t feel any movement or “click” like a button normally would produce.
I do not know of a way to do a factory reset from the button presses of the THETA V.
It seems like the camera is in an unfortunate boot loop with no connectivity via USB or WiFi.
If you can’t connect to the camera with adb (the program to access the OS shell inside the camera), the technique to do fastboot will not work.
I do not think the recessed button by the 3.4mm audio jack does anything.
Unfortunately, I do not have a good idea right now of how to move forward. As the THETA V lens assembly is still intact, the unit still has some value.
Thanks for your ideas and suggestions, Craig. I’m giving up on the V.
Fortunately, Ricoh just launched a Theta trade-in program. I’m going to see if they’ll give me a couple bucks for it, and maybe my Z1 (which I’ve always hated) as well, and put that towards a Theta X.
Thanks for the update. I’m sorry to hear that you had this problem. Just to let you know that we’re kind of in the same boat, I actually have an X that is stuck at the boot screen too. In my case, it does boot, but the WiFi and touchscreen don’t work because the in-camera default app is stuck at initialization.
I didn’t know about the trade-in program.
I did a search and found this:
Can you combine the trade-in with a discount?
January discount: Your Shopping Cart – RICOH360 Store
Hopefully, you can get the discount PLUS the trade-in. I don’t know. Just to be clear, I don’t work for RICOH and I don’t have any additional information on the camera sales and discount process.
