Theta V stuck in shutdown?
Hi,
I tried to turned off my Theta V and since then the power and camera status LED constantly blinks in RED (~ each 2 sec).
According to this page:
https://support.theta360.com/en/manual/v/content/prepare/prepare_04.html
“flashing in red” means “The power is turning off”.
Occasionally, there is a beep (or actually 3 short beeps, I think). The beeps happen at seemingly random intervals (from 1 minutes to 10+ minutes).
If I connect to a computer, the camera does not shows up as an USB device (lsusb).
Can you help me with this?
Thanks,
Attila
Hi,
There are 2 buttons to press at the same time to force shut down and probably reset the camera. If I remeber well, these buttons are on/off and wifi.
https://support.theta360.com/en/manual/v/content/settings/settings_04.html
If you have nothing to lose but your camera, give it a shot !
Hi @Samuel.L,
Meantime the camera shut down by itself and after a charging it’s working right now.
I will try this shutdown / reset method if it gets stuck again.
Thanks,
Attila
