I’m looking to buy a theta X for street view (because it has a gps and 8k 2fps mode).
I couldn’t find this info, but: is there a horizon level function in this mode, so every spot of the blue line looks leveled in streetview?
Thanks !
Thanks !
The THETA X has an option called _topBottomCorrection that is enabled by default. For the X model, this will also apply to the video.
It is on the menu on the body of the camera.
There’s information on Street View Studio here:
Introducing Street View Studio: The easiest workflow is coming to RICOH THETA users - #30 by craig
My test here:
You set 8K and the FPS through the body of the camera.
Make sure the triangle icon is solid, not outlined.
This is a community forum that receives sponsorship from RICOH. I do not work for RICOH. We are unable to supply official information. You should buy the camera from a place with a return policy in case it does not meet your requirement.
If you require official information, you should contact RICOH directly.
