We’re encountering frequent battery temperature errors on our Z1 while interval or video shooting. Its not hot out (~15C) or especially sunny. This device was used frequently in far warmer temperatures and for longer durations without issue last spring/summer so I’m not sure what has changed.
Thank you for your response. We’re running the latest firmware - 2.00.1. Using interval capture and no plug ins. I’ve been in contact with Ricoh support and it sounds like this is likely a sensor malfunction so we will have to have that serviced.
