Hi,
My Theta Z1 is blinking red and only thing I did was restart it. I don’t know how to solve this issue. help needed.
Regards.
Saad
Hi,
Regards.
Saad
what does the battery charge show after you’ve plugged the Z1 into a USB C cable for an hour?
Thanks @craig , I let the battery die down and charged for an hour. It started okay now
Be aware that the Z1 will turn on automatically from power off when the computer is turned on. It will also turn on from power off when the USB cable is first plugged into a running computer.
