Firmware version 2.30.1 is available. theta360.guide has tested in with several different plug-ins, and it works well. We have also interacted with multiple developers who have upgraded to 2.30.1 and results are very positive.
It is now possible to use Developers Mode. This means if you register with the THETA Plug-in Partner Program and are accepted, you will be able to download a version of the desktop app that allows you to unlock your V yourself. You cannot do plug-in development with a locked V.
The desktop app needs to be updated to the newest version (Version 3.5.0 or higher).
Other improvements:
You can save shooting conditions set with a smartphone on the camera.
Shooting conditions registered in My Settings will be enabled when you turn the camera on while not connected to a smartphone.
You can only use My Settings for still images.
Requires the latest version of the smartphone app (iOS 2.1.0 or above, Android 1.19.0 or above).
