Is there any limitation of the bitrate used with wireless live streaming plugin? In a wifi environment with the camera put exactly in fron of the router and everything in the local network I cannot go over 1 Mbps bitrate.
Did you adjust the bitrate in the web interface?
The Z1 supports the following:
IEEE802.11 a/b/g/n/ac (2.4GHz/5GHz)
Do you have the camera and your router set to 5GHz and 802.11 ac?
Hi, @craig san,
I’ve successfuly streamed 360(2K 1920x960) on YouTube with using THETA V & Wireless Live Stream Plugin.
This is the archive. mute the speaker due to the big noise.
We should set the resolution to 1920x1080 manually to avoid the holes both on zenith and nadir.
Tommorow’s night, I’ll be on air with Theta V and OBS from the venue.
Hope you enjoy.
Toyo
Please let us know when you’re on air!
Hi, Craig.
Thanks for the tips on here and youtube.
While I’m trying the livestream I could get in the web interface on my phone to control my live.
But now I can’t get into itm I don’t know why.
To change the stream key and qulity of my livestream I need to get in there again.
Is there any solution to do it?
Thanks~
